PROBLEM: Trim ram housing damaged. Looking for used one or is there a complete retrofit system for these models? The part number is 818055A 3. This part number is NLA.
the trim housing is same 1976-1994. it's not going to be cheap since you're going to have to kill a good system to get one. maybe you can find a system known to bleed down and cannibalize it.
no factory retrofit for rams. need a different transom clamp package to use the other trim system. there are jack plates with trim although I think the 120HP rating is expensive.
