montecarlols
- Oct 6, 2011
- 11
I decided to replace a few gaskets between the mid section and the lower unit last week. The rubber seal at the bottom of the exhaust tube and the paper gasket under the power head. Ran fine before, seemed louder than it should be so I took it apart. Now with it all together there seems to be no vacuum to the fuel pump, the crankshaft pulley seems to be easy to turn by hand also. Am I missing something here? Could the upper crankshaft seal have been damaged from the power head siting on it's side? Supposedly that seal was replaced by the original owner... Not sure what to do next, obviously I need to do a compression check(forgot tester at work). Just wondering if anyone has had a similar problem btw all new gas lines and fuel pump
