4 horse 2 stoke Johnson
geratur
Hi, can someone tell me how to adjust the fule mixture screw on a 2000 4 hp 2 stroke johnny? Is it the little red adjustment knob on the side of the engine the tiller is on? It starts, runs fine but troubles to idle, thank you !
1946Zephyr
Re: 4 horse 2 stoke Johnson
I believe that is your throttle stop. To adjust your mixture screw, you should find a adjustment screw on the front of your carb. It'll be number 10 in your diagram below. You might see if it is attached to a knob on the front of your motor.
geratur
wow, that was fast, and certainly accurate. Thanks a bunch, thats just what I was looking for ! is there a reference page for the rest of the numbered pieces to that diagram available?
nwcove
go to marineengine.com, find your motor, and you will see everything you want to see.
boobie
Try shop.evinrude.com, have your model # and look up your mtr.
