I have a 140 HP 1993 Model Evinrude V4 Ocean Pro...Took it out Sat...made a good 20 minute run on it ran slick as a whistle...then it started acting up. The motor will not "OPEN UP" when the gearshift is engaged. In neutral it revs and idles perfect. As soon as you put it in gear it Bogs down making a totally different motor noise and will not even get the boat on plane. Then back to neutral and rev...perfect. It starts cutting back the last time I took it out...I changed all 4 plugs and added Sea Foam...seemed to work like a brand new one after that for 20 minutes then rite back to the Sh!tter it went. Does anybody have any ideas? I don't want to take to a shop without half way knowing what is wrong...scared the high dollar labor charges will screw me. One guy told me maybe a coil went bad? I know there are 4 different coils on it as they are located right beside corresponding plugs. How can you tell if a coil is bad? Another buddy told me it was my fuel pump? Would the motor still idle and rev correct in neutral if the fuel pump is messed up? Anybody with experience or with similar issues in the past please chime in to help me. Possible things to check or anything I can do at home? As much as I fish I have to get OL PEARL runnin right again! Thanks to all!
