Ive started putting my powerhead back together, The block was bored and decked. new wiseco pistons. The crank and pistons went together without trouble, i got the engine cases bolted up . When i went to test fit the head and gasket, the tips of the dome are hitting the head with the head only pulled down not torqued .
I put Prussian blue on one of the pistons and here are the pics. Im thinking file it down to fit and clay check the clearance. You can how the factory piston is more rounded at that part of the dome.
