Re: batteries
Your objective is to protect the starting battery from being drained. Simply paralleling the added battery doubles the available current capacity but it does nothing to prevent discharging both of them. So yes -- you need to add a dual battery switch or if you don't want to be bothered with that, add an ACR (automatic charge relay). ACR's are wired so the primary battery (the start battery in your case) always gets charged first. When fully charged the acr switches charge current to the auxiliary/house battery. Unfortuanately, unless the ACR has a "combine" function, you couldn't start the engine from the house battery if that scenario every arose. A dual battery swtich allows running everything from BAT 1, BAT 2, or BOTH, charging BAT 1, BAT 2 or BOTH or starting the engine from BAT 1, BAT 2 or BOTH depending on what you have the switch set for. It also has an OFF position that kills everything. Dual battery switch installations are covered in detail in this forum. Use the search feature.
