goblerblaster
- Dec 26, 2011
- 176
OK, I'm about shot and ready to go to the shop !! My 2000 year model 115 Johnson would start and run fine for about 30 seconds, run out of gas and die. I can pump the bulb and it will crank and run fine for 30 seconds and die. As long as you pump the bulb it runs great. After 5 to 10 bulb pumping sessions, it will run WOT, idle, or in between, and no more bulb pumping all day.
After much traffic on this site, I have tightened all hoses, replaced the primer bulb, got a new (used VRO2) off ebay and now it will not run at all unless I spray primer fluid in the carbs. When I take the fuel line off at the fuel filter, it seems there is a lot of pressure on the fuel lines- it squirts gas everywhere. If I drain the carbs from the screws at the bottom of the float bowl, no gas comes out. I took apart the VRO and all gaskets and diaghrams are intact. When I pump the primer bulb, it gets hard and stays hard.
I had this VRO replaced less than 2 years ago at @ $700.00 and would prefer to figure this out ---with your help !@!!!
Any ideas appreciated.
