Gross Weight of 1980 Beachcomber Holiday 23'?
Re: Gross Weight of 1980 Beachcomber Holiday 23'?
Your Local TruckStop is the place to find out........... ;)
Joemayan
Thanks, I haven't bought this boat yet, it's sitting in a storage lot. Spoke with owner, looked at boat. My manual trans Xterra has a 3500 lb tow limit. The 1980 Beachcomber cabin cruiser I/O has a 230 omc. The only numbers on boat read<br />'Mirro Marine Division Model 207 I/O'<br /><br />This will be my first boat, if I decide to do it.
roscoe
You will be way over your tow limits.<br /><br />These weights do not include the trailer, fuel, water, gear; or items in your truck, like passengers and gear, which will ad atleast 1000#, probably 1500#, to the weight.<br /><br />Here is what I found for the 1980 model 22'.<br /><br />Length: 22' <br /> Model Name/Description: HOLIDAY 22 <br /> Boat Type: Stern Drive Power Boat <br /> Hull Material: Fiberglass <br /> Beam: 8' <br /> Engine: 1<br />260 HP<br />Gasoline <br /> Net Weight: 3,650 <br />*******************************************<br /><br />And this, for a 1981, 25'.<br /> <br /> Length: 25' <br /> Model Name/Description: HOLIDAY 25 <br /> Boat Type: Stern Drive Power Boat <br /> Hull Material: Fiberglass <br /> Beam: 8' <br /> Engine: 1<br />260 HP<br />Gasoline <br /> Net Weight: 4,500<br /><br />You need a BIG(real :p ) truck to tow this.
Joemayan
Thankyou roscoe, what do suppose a boat like that Holiday 22, in very good condition is worth?
