CarabbeanSafari
- Oct 25, 2011
- 25
Hi folks,
Question from Australia here I figured you guys have a lot more of these boats engines and may be able to help me, Thanks in advance kinda loooong story.
Boat imported by my Boss Bayliner 175 2005?
Engine 3.0 mercruiser says Nov 2005 on the top of air cleaner.
He used this boat once in salt water and flushed with muffs after use.
Used once in fresh water with "he says no problems".
Parked the boat in his front yard for 12 months untouched:facepalm:.
He Went to use it over xmas you guessed it no go!, He Asked me to come and have a look at his boat as warning buzzer sounded as soon as key moved to "on" position, I thought it had a flat battery. With a fully charged battery would not turn over so I pulled the plugs and it's full of water. Question where has most likely the water come from?
I pulled the head and manifolds, Couple of combustion chambers and valves are rusted, along with surface rust the entire top end, Top of pistons are ok?, Bores have water marks from top down to where pistons are sitting but no scores etc., Have not tried to turn bottom end manually until I work out how bad, The oil is not milky. My guess is the manifolds but they do not look overly bad just suface rust, Question to all you guy's is what's the most common problem with these engines? And what are your thoughts?. I have a local head machining and boring/honing guy who is great to deal with, but before i go down this track I need to source the problem. Or I may get fired
