Re: AQ140 power loss at high altitude
Sounds like the boat doesn't have enough power for that elevation and load. I assume the 79 AQ140A = 140HP, that would be 140HP at the crank, so it's about 125HP to the prop. Factor in the 3% elevation loss and the engine is only putting out a bit over 100HP to the prop. That isn't much power for a 19' glass hull and a load of 4-5 adults.
I run a 140HP Mercruiser in a 18' aluminum hull, 2000# boat. It hauls butt down at 1000', but at 6500-8800' elevation it's marginal at best with 2 adults and 2 kids, 600-800# of people and gear. That's with dropping 3-4" of prop pitch and re-jetting the carb.
Is there a lower gear ratio available for your outdrive? It won't be cheap, but might solve your problem and get you back up in a higher pitched prop.
What props have you tried, pitch and diameter?
Here's something I pulled from Mercruiser Manual 26, even though you have a Volvo, it's still good info for your problem.
Elevation has a very noticeable effect on the wide-open-throttle power of an engine. Since
air (containing oxygen) gets thinner as elevation increases, the engine begins to starve for
air. Humidity, barometric pressure and temperature do have a noticeable effect on the
density of air. Heat and humidity thin the air. This phenomenon can become particularly
apparent when an engine is propped out on a cool dry day in spring and later, on a hot, humid
day in August, does not have the same performance.
Although some performance can be regained by dropping to a lower pitch propeller, the
basic problem still exists. The propeller is too large in diameter for the reduced power output.
A Quicksilver Propeller Repair Station or experienced marine dealer can determine how
much diameter to remove from a lower-pitch propeller for specific high-elevation locations.
In some cases, installing high altitude gears in the drive unit is possible and very beneficial.
Weather conditions may effect the power output of internal combustion engines. Therefore,
established horsepower ratings refer to the power that the engine will produce at its rated
rpm under a specific combination of weather conditions.
