Re: Template for factory Sevylor Fish Hunter Floorboard
I did respond to CJ with a private response, but since there is more than one person interested I will post what I can here, for others to use as they see fit. Brief Recap: I used the shape/design/drawing that has appeared in this site's forum as a basis, but modified it from there. Since I intend to deflate and pack my boat between trips, and set it up at the water's edge, my floor is in 2 pieces. I included the 3 inch scoops at each end (bow/stern), not knowing why they were added, and see no use for them, so won't recommend them. Unlike others, I have not added piping around the edges of the floor, to protect the boat, but did sand the edges carefully and have painted the floor with an enamal paint, which I hope will provide enough protection. As noted, my time on the water with this set up to date is limited, and I might add piping later.
I had hoped to be able to photograph my floor boards last night and post them today, but life got in the way, so hopefully I will be able to do that tonight. I also plan to show length measurements, and a width measurement each 2 inches from bow to stern, assuming that should provide enough information to replicate what I have, to the extent you see fit.
In regard to dealing with the 6 plastic the line holders on the bottom of the boat: I believe that the Sevylor floor boards sit on top of these (not 100% certain). Wanting to avoid this much pressure on these 6 points, for the front and back 2, I put chalk on them and positioned the floor board on top, so that chalk marks would transfer to the floor boards, in those spots. The using a Dremel course sander, I made 'gouges' in the underside of the boards, at these spots. These went through all but the last ply of the plywood. When placed in the boat, my floor boards fit in front and in back of the 2 middle plastic rope holders very nicely. I can't claim this was intentional but turned out to be a very fortunate coincidence. Yes there is roughly a 1 inch gap between my front and back floor board but this does not appear to affect the stability and I intend to cover the whole thing with indoor/outdoor carpet, to prevent slipping and limit the loss of any small pieces (think snap swivels, shot weights, etc.) that might fall and bounce around.
I hope this helps. More tonight or tomorrow.
