2004 Optimax Problem
MR. Bass
I have a 115 optimax 2004 (DFI) run rough at Idle, Checked fuel pressure reading 30psi should be reading 88 psi to 92 psi, clean water sapartor out found, parts of old fuel line in chamber where filter is clean filter and chamber, looked at both fuel pumps screen they are clean. Changing the filter will this help and does anyone know what the reading on the pumps should be checking with a meter to see if on had failed.
