Black as
- Feb 22, 2010
- 417
Hi Don
I'm re-powering my 1988 Bayliner with a 5.7 lit Vortec engine that has a Cobra drive.
I plan to buy this distributor http://www.michiganmotorz.com/delco-...tor-p-119.html
I've read many threads in regards wiring this unit up but ask your advise, should I use the current e.s.a. shift module or set it up Merc style?
If you could assist me with drawings and advise on what I should look out for this would be greatly appreciated.
I'm also a little unsure about setting the timing on these units as I've read something about fitting a shunt wire to set the timing and then you remove it.
Your assistance would be greatly appreciated.
