clockworksquid
- Jan 6, 2012
- 2
Hi Everybody,
I'm in the beginning stages of starting a big art project, where a few friends and I are going to build a miniature pirate ship.
It's going to be a sort of spanish galleon, with the top being mostly plywood or something to that effect, and the bottom being a rowboat.
I don't have any experience with boats, so I've been doing some research, but I thought you guys would have some valuable pointers.. I know that building onto the top of it is going to make it heavy and awkward, and I don't want it to tip, so it sounds like a wood or fiberglass boat would be more stable in the water vs. an aluminum one...
However I don't know how I would go about attaching the top part of the ship to the rowboat if I got a fiberglass boat, because from what I can tell you dont want to just drill and bolt into it...
Aluminum seems to take the best beating, but is more unstable and also cold and loud (we will fish from it from time to time)..
The masts will also probaby be an issue, and might be purely for show and usually closed to prevent it from just blowing over sideways, we will probably just scoot around the canal here with some oars.
So I guess my biggest question is what type of rowboat should I be looking for?
Fiberglass sounds good but then I don't know if it is feasible to attach the top half of the galleon to it?
Wood sounds good but is... a lot of maintenance?
Aluminum would probably be the easiest to bolt the top half of the ship to but we would all freeze our butts off and most likely tip over?...
Questions?
Comments?
Thanks in advance for you insight!
F!
Questions?
Comments?
F!
