Okay, here we go again, I am sure some of you are saying. Anyway, I am repairing my aluminum jon boat because PT plywood was used by the manufacturer in the transom and it is causing a significant amount of corrosion. I think I have caught it before it was too far gone. What I want to know is if I epoxy coat and seal the PT wood will that help prevent the transfer of the cooper ions in the PT wood to the aluminum and prevent the corrosion process?? (Or aluminum Ions to the copper whichever it is I don't care for the politically correct chemists out there). The moderator has already said it won't work so I am assuming he has tried this or read about someone that has? Has anyone else tried this with any success??
Thanks for the help.
