jason32038
- May 25, 2009
- 555
I was wondering if any of you knew off the top or your head what the throttle cable tension should be set at. Could anyone with a mid to late 80's force take off their throttle cable and measure the distance between the nipple and the actual cable connector for me? I had "play" in my throttle as in one direction would throttle faster and the other would be slightly delayed and also wouldnt move linkage back all the way to return to adjusted idle speed on land. I dont remember if it was forward or reverse because I havent fired it up in 5 months. I didnt search iboats because it always comes up with a jizzillion of unrelated results to sift through. Any help or suggestions appreciated thanks!!
