Re: I am going to kill myself.
On your engine, you have a slave solenoid for the starter as well as the starter solenoid on the starter. Here is a basic wiring diagram of your starting system.<br /><br />
<br /><br />First thing you have to do is make sure all the battery connections are tight and clean. This includes the ground connections on both ends. If it's all green and corroded then it will probably kill all the power to the starter and you will only get a click...... sound familiar????<br /><br />Ok, lets say the cables are all good, clean and tight.<br /><br />Locate the slave solenoid on your engine. Should be on the starboard front of your engine (I think)<br />Looks similar to the picture below.<br /><br />
<br /><br />Note the wire color codes, because A, and B could be backwards from the diagram, along with C and D and it will still work.<br /><br />First thing you need to do is remove the coild wire out of the distributor cap and ground it to the block somewhere, and make sure there are no gas fumes in the engine compartment as you are going to be making some sparks.<br /><br />Take your jumper wire and hook one end to the Positive terminal of your battery. Take the other end and touch to termainal A of the slave solenoid (yellow red wire). When you do this, the engine should crank so be prepared. If it doesn't crank, touch it to the other yellow red wire <br />(Terminal D) if it now cranks, go back and try A again, if it clicks again, you have a bad slave solenoid. If it clicks when you hit terminal D with your jumper, then the problem is either the wire going from the slave solenoid to the starter or the starter itself.<br /><br />Here is a picture of the starter and solenoid.<br /><br />
<br /><br />If you touch your test lead to terminal B, and the engine cranks, then your problem is probably the wire or connections between the slave solenoid and the starter.<br /><br />If it just clicks, touch your test lead to terminal C. (Careful, it could get hot and burn you). The starter motor will run, but it won't crank the engine. If the motor runs, the starter itself is good, but the start solenoid is bad.<br />Probably easiest to just replace the complete thing with a MARINE starter, don't go automotive.<br /><br />And be careful of where you touch that test lead. If you touch any ground it will spark and get hot. It's not fused and will melt and burn if you don't pull it off quickly.
