liquid assets
- Dec 21, 2011
- 6
I bought a 25 hp suzuki (1987) the motor was getting hot so I changed the t-stat and the empeller, still getting hot after about 4-5 minutes running...there is an exhaust/water cover plate on the port side of the motor...well when I attempted to take this off it already had numerous bolt heads broke off, anyway's now the plate is in a few different pieces actually both plates broke and all the bolts are still in the motor? any body know how I should go about this without having to pull the motor head off? should I heat the motor block around the broken bolt or heat the broken bolt?
when I finally got these plates off nothing looked like it was blocked/clogged, are there any small holes in the water jacket? because all the ports I could see are bid enough to put a screw driver in, I am at a lose..dont' know if i should try to buy new cover plates and put it back together...someone please help!
