oil injection to premix
xengrns
I am working on a yamaha 40 hp. 1987 model. the injection pump is trashed and he wants to use premix.does anyone know what I need to disconnect so it will run at wot.
99yam40
Re: oil injection to premix
What is wrong with the oil pump?
They do not normally fail, maybe trash in tank or oil is jelled up.
Need to drain and clean tank and all lines from time to time just to make sure.
If you are dead set on removing make sure you remove the pump drive shaft so it will not ruin the crankshaft when it seizes up from lack of lub from no oil.
Do a forum search as this topic has been covered many times
