Re: Battery wiring question
On a boat that size I would retain the three batteries but with drastically different switch wiring and there would be a multitude of ways to use them. However, I subscribe to the principle that keeps things simple. Therefore switch 1 would allow charging battery battery 1 and the house battery (call it battery H). Switch 2 would control battery 2 and and the house battery as well. The house battery is what powers the cabin lights, electronics, etc. Battery 1 and 2 are then reserved for starting engine 1 and 2 respectively. You could also have this configured so you could start engine 2 from Battery 1 should Battery 2 go flat, and vice versa you could start engine one from battery 2. One thing you want to avoid is the possibility of ever allowing the alternator on either engine to run with no load as so many settings in the current setup allows. Don't hesitate to use an ACR (automatic charge relay) which is similar to the Guest device you have. An ACR take alternator output and designates one of its outputs as the priority output which is usually the start battery. When the engine is running the priority output always charges the start battery until it is charged. It then switches to the auxiliary output. As with an isolator, the ACR will not allow the two batteries to interact unless the ACR has a combine function which would be like the BOTH setting on a switch. Take your time and work with one engine and charging system at a time. Then figure out how or if you even want or need to interconnect them. If you spend a fair amount of time operating on one engine, the ACR could be very handy in charging the non-operating engines start battery.
