I just started my second boat restoration. 1st one was a learning experience. I am working on a 87 Sea Ray Sorrento 21 foot open bow. I thought i could just replace some soft spots in the floor, but upon further investigation, this is not the case. I will be replacing all the stringers and transom.
I am doing more research this time trying to do the best job i can, and have a few questions.
What is the best way to build the cover for the in-floor gas tank? The original design had a large removable plywood panel, but it seems like this area is the first area to allow water intrusion, and had the most rot. I have seen a video where a permanent panel was screwed down and glassed over. If I did this I would use one of those plastic access covers for the fuel sending unit in case of future problems. Any thoughts or experiences? Pros and Cons?
Thanks
Thanks
