Hello All,
Have a question regarding spray in foam. I like the idea of foam but in removing sections of my deck I noticed alot of voids and areas where when water got in it just pooled up with nowhere to go. I have a company that is close to me that does a spray in foam on construction sites called Icynene that comes in several forms open & closed cell. I think if I leave the deck out and have them spray in the closed cell which hampers water absorption I could get 100% filling of any open spaces there by eliminating any voids and areas where water can possibly stay. Excess foam can be trimmed back flush to the top of stringers and there would be no holes in the deck to plug up. Here is some info one the foam please let me know what you think...
PRODUCT SPECIFICATION
1. PRODUCT NAME
ICYNENE MD-R-200? is a trademark
for medium density, 100% water-blown
polyurethane spray foam manufactured
by Icynene. ICYNENE MD-R-200? is a
nominal 2 lbs/ft3 density, free rise material.
2. MANUFACTURER
ICYNENE MD-R-200? is made on-site
from liquid components manufactured
by Icynene Inc. Installation and on-site
manufacturing are supplied by independent
Icynene Licensed Dealers.
3. PRODUCT DESCRIPTION
Icynene?s next generation of high
performance products includes ICYNENE
MD-R-200?, a 100 % water-blown foam
insulation and air barrier material containing
resins with pre- and post-consumer
recycled content. This unique product is
a tough, low water absorption product
with applicability across a broad range of
substrates, environmental conditions and
climate zones.
It is a type III vapor retarder, with low
vapor permeance. It can be used to limit
diffusion of moisture through building
assemblies.
ICYNENE MD-R-200? insulates and airseals
in one step for maximum energy
conservation while minimizing the
environmental impact during manufacturing
and construction. Significantly reducing
air leakage means ICYNENE MD-R-200?
contributes to a healthier, quieter and more
comfortable indoor environment, while
reducing energy consumption and related
greenhouse gas emissions by as much as 50%.
The result is superior quality construction,
with higher comfort levels and lower
heating and/or cooling costs. Energy
savings will vary depending on building
design, location, etc.
ICYNENE MD-R-200? is applied by
spraying liquid components onto an open
wall, crawlspace, ceiling surface or cathedral
ceiling. There it expands approximately
30 : 1 in seconds to provide a foam blanket
of millions of tiny air cells, filling building
cavities, cracks and crevices in the process.
It adheres to most construction materials,
sealing out air infiltration.
Excess material is trimmed off, leaving a
surface ready for drywall or other codecompliant
finish.
4. TECHNICAL DATA
(Based on Core Samples)
Contains Recycled Content
Thermal Performance
Thermal resistance (ASTM C518)
- R/in = R5.2 hr. ft2 ?F/BTU
Average insulation contribution in a
stud wall:
- 2? x 4? = R16 (3? foam)
- 2? x 6? = R26 (5? foam)
ICYNENE MD-R-200? provides more
effective performance than the equivalent
R-value of air permeable insulation
materials. ICYNENE MD-R-200? is not
subject to loss of R-value due to aging,
windy conditions, settling, convection or
air infiltration; nor is it prone to traditional
moisture intrusion via convective air flow.
A FACT SHEET with R-value data is
available upon request.
Air Permeance/Air Barrier /Air-Seal
ICYNENE MD-R-200? fills any shaped
cavity, and adheres to most construction
materials, creating assemblies with very
low air permeance. Additional interior or
exterior air infiltration protection is subject
to applicable codes.
Air permeability of core foam:
ASTM E283 data:
- 0.0016 L/s.m2 @ 75 Pa for 2?.
ASTM E2178 data
- 0.0015 L/s.m2 @ 75 Pa for 2?.
All buildings, insulated and air-sealed with
ICYNENE MD-R-200? must be designed
to include adequate mechanical ventilation/
outdoor air supply. See ASHRAE Standard
62 ? Ventilation for Acceptable Indoor Air
Quality.
Water Vapor Permeance
ICYNENE MD-R-200? is a type III vapor
retarder with low water vapor permeability
reducing the amount of moisture that can
diffuse through the insulation.
Water vapor transmission properties:
(ASTM E96 Desiccant Method)
- 1.3 Perms @ 3?
Water Absorption Properties
The absorption of liquid water is very low.
Water Absorption, % by volume
- ASTM D2842: 0.57%
Burn Characteristics
ICYNENE MD-R-200? is a combustible
product and is therefore, consumed by
flame, but will not sustain flame upon
removal of the flame source. It leaves
a charred foam residue. It will not melt
or drip. ICYNENE MD-R-200? is
subject to all National/State and County
building codes regarding fire prevention.
Requirements for Thermal Barrier and
Ignition Barrier coverings must be met as
per the applicable building code having
jurisdiction.
U.S. Fire Testing
Surface Burning Characteristics
(ASTM E84) @ 2? thickness
Flame Spread ≤ 25
Smoke Development ≤ 450
*Flame spread rating not intended to
reflect hazards under actual fire conditions.
Plastic Piping
ICYNENE MD-R-200? is compatible in
direct contact with CPVC piping systems,
as per Paschal Engineering Study for the
Spray Polyurethane Foam Alliance.
Bacterial or Fungal Growth and Food Value
Independent testing conducted as per
ASTM C1338 showed that ICYNENE
MD-R-200? is not a source of food
for mold; and as an air barrier material,
ICYNENE MD-R-200? restricts the
airborne introduction of moisture,
nutrients, and mold spores into the
building envelope.
Environmental / Health / Safety
ICYNENE MD-R-200? is 100% waterblown
and therefore contains no ozonedepleting
blowing agents. It is also PBDE-free.
1. PRODUCT NAME
2. MANUFACTURER
climate zones.
assemblies.
finish.
4. TECHNICAL DATA
Thermal Performance
stud wall:
ASTM E283 data:
ASTM E2178 data
Quality.
- 1.3 Perms @ 3?
- ASTM D2842: 0.57%
jurisdiction.
U.S. Fire Testing
Flame Spread ≤ 25
Plastic Piping
building envelope.
