Ive got a 1981 vintage 90 Johnson. Great Running motor. Been on the boat ever since my dad bought it new in 1981. ~125 psi per hole compression. Great engine. He gives it to me and of course I have to take something sweet and make it dirty. Anyway, I want to do the 140 HP conversion. 120 Honest HP would be good. So I figure I need a few things to make this happen.
1. A 115 or 140 carb set. Bought a complete unit on Ebay for $30.
2. Possibly a reed spacer set. More than likely not needed but I can look.
3. A bubble back exhaust manifold and cover. Ive been looking. I can probably pick one up for $100 ish but cheaper is better. I'm still looking. They do not seem to be in abundance.
4. The block. a 115 or 140 block will do but I'd like to use the 90 block and punch the ports out if thats possible. I have access to a mill and if its just a question of running a cutter into the port and opening up the ports to a larger size I could do that then debur and hone the block. I do not know the offset though if there is one. Is there any port offset? What size are the 90 HP opening and what are the 115/140 port opening sizes?
Has anyone done this to theirs. I know the standard warnings but its something i'd like to do and I'd like some constructive comments or advice from those who have attempted this..
