1973Chieftain
- May 31, 2010
- 1,298
Late last fall I purchased a Jet and ended up with a '94 40 HP Force long shaft to repower it with. However, the Jet has a short shaft. I've been looking at my options and reading how several other folks on here removed the old transom and put a new one in that is taller, also how some folks used either a jack plate or a transom elevator to raise the engine up. Has anyone used either on a small Starcraft? It seems to me that either would be much simpler then removing the transom, and has the benefit of reversibility should the need arise. My main concern is that it seems that they both add extra stress to the transom which worries me a bit. I'd appreciate any thoughts!
