Re: Need help please, looking for wiring diagram for 9.9hp Johnson 1998 four stroke
Thanks Haffiman,
your post was very clear and easy to follow.
unfortunatly, still no spark.
there is a grey wire that looks like it goes to regulator, do i need this hooked up to + or -, or don't need?
Also there are two blacks,
black/white shows restance to block (ground)
black/yellow I have no idea where it goes?? (maybe dont need it hooked up)
brown = temp sending unit (i left disconected)
brown/yellow = oil sending unit (i left disconected)
If it should of had spark from coil pack after i hooked up as stated above, maybe there is problems with electrical components, kinda lookin that way to me.
I have a book now, not a good one, but hopefully it will help diagnose.
if you have anyother ideas, i will be glad to try
Thank you
