Re: What size nut on a 90hp flywheel ?
I use a BIG 3 jaw puller an impact wrench and a 2/3# hammer.See pic.
Loosen nut,don't remove all the way.
Insall puller and tighten as tight as it will go and then a bit more.
Then hit with a hammer on the end of the puller bolt.
Use gloves and keep your hands away.It will come off with FORCE!!!
That's why you leave the nut on.
I don't like to use heat as you can ACCIDENTLY melt the top crank seal.
