I got the ST1290-60 Trim tabs. In the actual plate there is 3 holes. If i use the two closest to the boat I dont have room for the actuator and keeping the plate at a 25 degree angle. If I use the middle hole and the rear hole I have enough room. Can I use the back holes or will this be putting the actuator in a bind. Im hoping the holes are there just for this reason.
Thanks in advance for any help I get.
