I have great spark, tested fuel pressure and that also was great, I am now clueless on why she wont even sneeze, just cranks?? any suggestions would be great, thanks
With your safety hat on, I'd be looking at ways to see if the MPI is really doing it's thing. I am also assuming you checked for spark at the plugs?
I used my spark tester and confirmed a good spark at each cylinder,
Btw,... A 6.2l is Not a 350, so which do ya have,..??
Your fuel pressure is to low at 30 psi, The correct specification is 43 psi.OM327932, any suggestions would be greatly appreciated, I am at my whits end with this thing!!
you should be able to shoot some starting fluid in the intake and get something
she will run on starting fluied.
and if it dont run on starting fluid, you will know its spark or timing
I was also going to suggest starting fluid just to see if it fires... What are the negative consequences of using starting fluid just long enough to see if it will fire?
