67searaysrv180
- Jul 4, 2005
- 3
Hey all, I am new to boating and have a question, I was given a 1967 searay srv180 sport- buick v6 omc OD, boat needs paint otherwise its mint less than 10 hours on newly built motor my problem is the electric shift lower unit kicks out of forward if I get into the throttle to fast, did a basic check and everything seems ok except rev. is getting 12volts at the transom connector but forward is only showing 10.4 volts, would this cause it to kick out of gear? the volt drop is from the control switch 12volts into switch 10.4 out to forward I'm learning as I go, <br /><br />thank you for any help<br /><br /> Norm
