Hello all, I own a Haines Signature bow rider that I have had for the last 4 years. It is fitted up with a 4.3 liter mercruiser(the throttle body injection version). When I purchased this boat the engine was a quicksilver remanufactured one. After purchasing I had a few niggly problems that the dealership tried to sort out. Most problems have been sorted and last season everything was going pretty good. One thing that has always occurred is during a high rpm run you would get a hot oily smell and at the end of the day there would be oil around the front of the engine and engine bay that would be typical of a fine mist. Since owning the boat I have never done the oil changes I have had it done by certified marine mechanics. This year I thought I would do it myself, I picked up the oil and filter from an authorized mercruiser dealer, they ran my serial number to ensure I put the correct oil and filter in/on. I sucked the oil out with a vacuum pump and observed almost 6 liters came out. I thought this odd as the service manual states 4.3 liters to fill with new oil filter. I changed out the filter and proceeded to fill the engine. This thing took 7 liters and is in the middle of the full-empty lines. I ran the engine on high idle and then stopped it, let it sit for ten minutes then rechecked the level. No change. This appears to be way more oil than the service manual states. Took the boat to the water for a run and the boat started easily as usual, ran nice at 3500 rpm while cruising. When rpm was taken to 4000-4200 after a couple of minutes the burnt oily smell appeared but something new happened. The engine felt like it was losing power and then a rattling sound like there was no oil and the a quick backfire. I dropped the engine back to idle immediately, then within 30 seconds the engine became quiet no rattling(which by the way sounded like noisy lifters) I proceeded to drive slowly increasing rpm to around 3000 with normal performance. This hashad me stumped. Now a week later I am on the family holiday with the boat and yesterday I launched her and the exact same thing happened. As I do not wish to damage my engine she is now parked up until I can determine what is causing it. First and only thing that coes to mind is too much oil that is foaming from the crankshaft.
Please help.
Please help.
