Hey everyone,
New to the forum, been lurking awhile. Currently troubleshooting a 9.9 Evinrude. The motor has sat for about 5 years, and I had cleaned the carb out, as it was gunked up solid. Now, I ran it and it ran great, but then it died out on me after about 5 mins in the tank. I did a spark test on it prior to running the motor, and it was an orange spark, not the bright blue 1/4" gap you want. I did a resistance test on the coil under the flywheel, and got 1.1 ohms of resistance, and checked the points and have them both at .020 gap. I ran a spark check again, and its still weak orange. I noticed the armature wheel under the flywheel has sloppy play, and sometimes if you move it just right it will fire off, then die out. Coil 1 has a high primary resistance at 1.3 ohms, Most coils i have come across are in the .03-.08 ohms range. coil 2 has a primary resistance reading of .2ohms. I did a voltage output test from the coil under the flywheel with a DVA attachment and got 202VDC. Any reccomendations on what to try next?
thanks for any input
