Im in the right forum! But after searching around for threads on the subject I can't find anything exactly like mine. So here goes...
I just got a jetboat for a good price+trailer. But its not starting. Seller told me he started and ran around back in September and since he just let it sit.
Motor is in a Regal Jetboat '94. It spins fine when the spark plugs removed. With the spark plugs on, its getting jammed at certain spot and wont crank. I dont know what is causing the problem. So I took all the spark plugs off and did a compression test. Cyl 1(bottom) 20psi, Cyl2(middle) 54psi, Cyl3 (top) 40psi
I know its not right with compressions that low. I haven't been able to do the spark test because I misplaced the spark tester somewhere.
So im hoping that its not causing by something which requires a complete rebuild.
