Hi All,
In removing my engine from the boat for a rebuild, I managed to shear off the heads of all four front engine mount bolts. I have a 5.0 VP GL engine in a 2001 Glastron 205GT.
I spent the better part of yesterday soaking them with the PSF/Acetone rust solution and attempting to extract them using a bolt-extractor set. No luck. At this point three of the four almost certainly need to be completely drilled out because I tried using the largest reasonable extractor size (probably 60% of the screw shank dia). The fourth screw is mostly untouched.
The reason I'm posting is because the front engine mounts appear to be threaded inserts retained mechanically by the fiberglass hull. That is to say that I don't believe the heli-coil-esque solution is applicable here. In attempting to extract one of the holes I got a little bit of wood coming up the hole when drilling, so I would guess that it's some sort of wood block/fiberglass composite sandwich. My inclination is that I'm going to need to completely drill out the threaded insert and bond in four replacements. I plan on trying to create a template off of what's currently left of the screws to try and re-locate the new inserts.
Does anyone have any experience with this? Any suggestions for inserts, bonding, hole prep?
Attached is pdf with a few slides of the holes
