TN28 Float
bonzoscott
How does this float and pin look? Maybe coat it with dope and see if it floats? This carb is far different from anything I've known. Is there anything else I should look out for to avoid a train wreck?
1946Zephyr
Re: TN28 Float
I think they'll clean up good. Then re-coat the float. If push comes to shove, you can get a new float at Sea-Way Marine.
boobie
Re: TN28 Float
IMHO I'd get a new float and be done with it.
HighTrim
Re: TN28 Float
As you found out, the TN carb is a bit of a different beast. I know the first time I opened one up I asked for pointers.
This site is about the best help you could get, rather than typing out a lengthy post, Ill simply copy and paste.
Those floats are easily made, harder to actually find. They dont sell rebuild kits for the TN. Even the impeller is no longer available. I took an impeller out of a newer 5.5 and ported out the center a little to let it fit the TN shaft.
Anyways, this will help.
http://www.pochefamily.org/outboard/CarbService.html
1946Zephyr
Re: TN28 Float
Ahhhh, come on boobie, that float has lots of life left in it. :D
boobie
Re: TN28 Float
Just curious as to how it would fair with this great ethanol fuel we are now blessed with.
tx1961whaler
Re: TN28 Float
I have a couple of corkers re-coated with fuel-proof dope in two engines for a couple of years. I also have a re-coated one that has been floating in a jar of 10% ethanol 50:1 mix for a year and it doesn't seem to be sinking.....
1946Zephyr
Re: TN28 Float
Yea, that one in the picture above, if it's cleaned up and treated right, I think it'll do okay. I have several oldies with cork floats, including a 1947 Sea King 5hp and it's doing just fine.
boobie
Re: TN28 Float
TX1961, what kind of fuel proof dope did you use ??
1946Zephyr
Re: TN28 Float
Yea, I get to go through the carb on my HD-20, so this will be some good info.
boobie
Re: TN28 Float
Would Gasoila work on that float? Or finger nail polish ?
HighTrim
Re: TN28 Float
I have tried a few different concoctions by coating old floats then letting them sit in a jar filled with fuel for a couple months to see how they hold up. Have not tried Gasoila or finger nail polish. The model airplane dope seems to hold up the best so far. I know some guys use the finger nail polish on the welch plugs on the carb, so I cant see it breaking down, but who knows.
