My 90 Johnson suddenly lost power to the point that we could only crawl back to the boat ramp but as soon as I cut the revs it stalled. The only way to keep it running was to have it on full throttle, but it was only running at less than trawling speed.
I checked the spark plugs, 3 were good and one had a melted center electrode with pitting around the lip of the metal case.
I replaced all the spark plugs with Champion QL77JC4 plugs(the same as I had run for a number of years). I put the ear muffs on it and it seemed to run well and started well. I then took it for a run and it just didn't seem quite right. It was a little slower to start than normal and it had a slight intermittent miss. I was running at about one third throttle when it lost power and again I had to crawl back to the ramp. Checked the plugs, three were good and one had a flattened side electrode with pitting on top of the side electrode and again around the rim of the metal case. A different cylinder to the first time.
I'm not sure what's going on. My thoughts are tending towards the timing but I haven't encountered this before. Fuel is pre-mixed.
Any input would be greatly appreciated. Thanks.
