Re: 1990 force 150 help and ?ss!!
Hey Justin
As with anything, things can go wrong. Is the boat/motor well maintained? You could have a well maintained Force run better than a neglected Johnson- for example. It's like anything- you take care of it, it will take care of you.
Just (if possible) do a compression test, and budget for changing the impellor or just do the waterpump anyways- assuming compression is good. Otherwise, I am the happy owner of a 1988 Force 125hp, and they are the easiest, best engine to work on yourself ever......
Hope this helps mate- and welcome aboard.
Justin
