Re: MFG Carefree floor
Thanks for the ideas and information.
So far in one 4 hour session I have taken the deck off the boat by using a multi tool to cut the seal at the gunwales from the outside.
I THEN CUT THE TRANSOM SEALS BY GOING IN BETWEEN THE HULL AND DECK AT SPLASH WELL. THERE WAS A BONDO LIKE MATERIAL UNDER THE GUNWALES AT THE DECK AND ON TOP OF THE TRANSOM PLYWOOD CREATING A BOND. I Think (sorry I hit caps lock , not yelling) it may be Seacast but not sure.
Once I removed the top cutting the transom out was a snap and the inner piece came out intact but wet. It needed to be replace but could have been much worse.
I began to explore the floor as it was soft and very flexible. I began under the seat pedestal and cut the top off, wet foam and disintegrated plywood. Fortunately there was a small hole nearer the stern by a herringbone reinforcing rod in the floor . I really sensed a gap between the inner tub and outer tub so I cut in and took out a small square. There was what was left of balsa or ply perhaps 3/16 thick between the two glass layers. It was paste. I worked my way to the gunwales and transom area to better understand the construction where the floor meets the sides and found it consistent. Took the multi tool and cut the perimeter from transom to front of seat pedestal and removed all the sludge.
Did not go further yet.
Moved to the elevated bunk in the bow felt a lot of flex and bored out a hole, perhaps 2 gallons of water poured out . Cut the glass top and pulled out saturated foam and scraps of ply. I think the water got in through bow eye bolts and was trapped.
Thats it for now, trying to figure out what to use to rebuild the floor, I would like to use Azek plastic lumber but need to find out if fiberglass will stick to it????
Thanks,
Lebowski
