Bybsurfr32
- Dec 11, 2011
- 1
Ok, this is probably a shot in the dark, but I figured I'd try.
I just picked up an 86 Shadow Bass boat. The wiring is so messed up it is unbelievable. There are wires all over the place. The guy before me jerry rigged everything so bad that I can't tell any of the wires apart. I've been in the garage with a test light and a connectivity meter for the past 5 hours trying to make some sense out of it. So far I have the lights working and a couple gauges. My RPM gauge comes on when I turn the key but that is the only gauge that comes on. When I ground the fuel gauge it stays on no matter what position the key is in. When I try to plug the fuel gauge wire into the sending unit on the tank, the wire starts to smoke. The bilge pump wires are also messed up. I can get the pump to kick on but i cant get it to work with the automatic switch.
Basically my question is: Does anyone know of a place that I can get a wiring diagram for this boat? Or maybe a boat very similar to it? If anyone has owned a Shadow any advice or insight would help a lot.
Thanks
Thanks
