Lower unit oil leak
Old Mercury
I have 78 Mercury 200 with an oil leak that is coming from "inside" the cone of the prop where the prop connects to the drive shaft. I am assuming that there is a seal around the shaft that is bad.? When I fill up the lower unit it will run out of the top fill hole but also run out of where I described above. What is the problem? thanks for any help
Faztbullet
Re: Lower unit oil leak
Several things on this motor, leaking upper driveshaft seal,cracked bearing carrier or damaged propshaft seal.
