I have a '96 88 SPL, that I've been having a hard time getting to turn over. The starter seemed to not have enough juice to turn the flywheel, which caused me to end up pulling the lower unit, turning the flywheel by hand without plugs, etc. After a water pump replacement, everything seems to check out except:
I have gone through the starting circuit troubleshooting in my service manuals and those suggested on this forum. I opened and cleaned the starter and cleaned/repaired all connections and grounds that I could find. Voltage to the starter was very low, around 2.5 volts. I tested the solenoid and made the determination (right or wrong) that it was bad. I purchased another solenoid and installed it. With everything hooked up, the solenoid now simply clicks rapidly with the key turned to the start position, and the voltage is still testing at around 2.5 volts. With the positive cable disconnected from the starter post, the solenoid clicks once when the key is turned to start, and sends 12 volts through the positive cable, appearing to function correctly.
Any advice on what the problem might be, or next steps in troubleshooting the issue?
Thanks.
Bill
Thanks.
Bill
