muskrat808
- Jan 24, 2011
- 106
Hi- Deciding what F/W separator to put on 1972 140 hp mercruiser ,specifically what GPH rating and Racor vs Sierra . Read the article from Feb 04 Trailerboat mag which says you can buy a Merc Bracket and use either Racor or Sierra filters , but if you get the Racor bracket you are stuck using only the much more expensive Racor filters . Talked with local West Marine and a couple other places and they didn't know what I was talking about . Wondering with a motor that old is the Racor overkill ? But do plan to add a newer kicker running through the filter however .- Thanks
