seattle scott
- Nov 1, 2011
- 113
this is a "barn" engine of unknown history. Was having fuel dripping out the carbs, followed everyone's advise and replaced the inlet needles and adjusted the floats and no more dripping. Engine running in a tub. Starts in 2 seconds, good water flow and after five minutes water discharge temp is bathwater warm. New gas and mixed 50:1. Spark plugs are new and when inspected have no fouling/carbon etc., but are wet with fuel. Exhaust is white smoke and if I was on the water it would look like a boat fire. It has Tillotson TC carbs and I can find no lean/rich adjustment, just the idle needles. Sucked a bottle of Sea Foam into the fuel line and the engine ran on straight Sea Foam for a few minutes. ( holly smoke batman) Shut engine off and waited an hour then ran it on the 50:1 gas until Sea Foam out of system, (fuel in see though in line filter went from clear back to the blue tint of the 50:1 mix). So anyway there is a horrable degree of white exhaust smoke.
So should I check compression to see if bad rings? If OK, then what?
I know if have excessive or unburt fuel in the cylinders because of the "wet" plugs,so is this causing or contributing to the smoking? Is there a way to lean the carbs? The engine has the vacum or breather hose system that transfers the crankcase gases around between the cylinders to reduce fuel consuption and exhast emissions, which I have not checked. I have not checked/adjusted the timing.
I will try to get a photo up tommorow since the smoking was truly amazing.
