Hello everyone!
I recently traded one of my Harley's for a 1996 Hydra Sports Ocean Skiff. Its powered with a 96 175 Ocean Pro. I know it sat for a while. I took it out for the first time this past weekend. It would run well for 2 to 4 mins on WOT. But it would then slow to crawl or drop RPM's to like some type of middle gear. It will also only idle for so long, spits a bit, and then stops, but fires right back up again.
I pulled the air cleaner off the front and watched it run while it was on the water at speed, I noticed on all the carbs, it had a white, milky looking , liquid on the boot of the carb. Like water?
I would love to hear suggestions as to where to go next. I would want to prevent unneeded work. The boat and motor only have 65 hours on it.
My first thought was to somehow drain the gas tank, lord knows where or how to do that. I have not change the fuel filter yet. guess that might be next.
Thanks in advance for any and all advise.
Chip
Chip
