My 03 carbed F90 misses and coughs and bucks on the transom for minutes last 3-5 times when I start it,on muffs, every couple weeks or so when I can't get on the water. It seems to be missing on 1 cyl. If I tilt the motor +/- 22.5 degrees up from level, it starts to idle fine! and I can return it to level and it idles fine. Could this be a carb float issue? I got this motor used and believe the carbs have never been disassembled or cleaned from looking at them. This happens w, or w/o using the primestart.
