Testing an ignition coil from an Evinrude 4416 2hp.
Can anyone tell me how to test an ignition coil from a 1947 Evinrude 2HP model 4416 with a voltage multi-meter?
Joe Reeves
Re: Testing an ignition coil from an Evinrude 4416 2hp.
No idea how to test with a voltage meter. However, obviously the coil must not be cracked, and the following will tell you if the internal wiring of the coil is as it should be.
(Regular Magneto Coils - Continuity Test)
(J. Reeves)
Checking the continuity of the ignition coils....... Have the ohm meter set to High Ohms.
Remove the primary wire from points. Remove the coil ground wire. You do not want either of these wires touching anything.
Connect the black lead of a ohm meter to the spark plug boot terminal, then with the red ohm meter lead, touch the ground wire of the coil.
Then touch (still with the red lead) the primary wire. You should get a reading on both touches (contacts). If not, check the spring terminal inside the rubber boots of the spark plug wire.
If there is no continuity between the secondary circuit (spark plug) wire and the primary or ground, remove the coil from the armature plate, then check the continuity directly between the prong within the coil (prong that the plug wire connects to) and the primary and ground. Poor or no continuity of a coil (or plug wire) is one reason for weak spark, s/plug fouling, or no spark.
AlTn
try a You Tube seach for "Testing an antique outboard motor coil" as well
steelespike
The old style coils, Paper wrapped not molded are very reliable. As alluded to in the test
there could be corrosion in the plug wire or plug boot, 47 may not have a boot,but could have corrosion where the contact is attached. or at the coil. I believe the old coils the wire is soldered at the coil.If yoiu suspect the wire at all I would replace it with new solid core wire.
