Re: cobra ? are these years compatable
Parts from one outdrive can be transfered to the other if they aren't worn out and can be removed without damaging them, but you would need a complete gasket kit, seals, bellows, shim kit, and potentially a water pump kit, bearings, housings or other minor parts. if you'd be re-using your existing upper & lower gearsets, I'm curious why you need to find a new outdrive in the first place. The gearsets (if in good condition) are the most useful part of a used outdrive.
Also, installing a gearset in a different case will require the use of a special jig and tools, following a precision shimming procedure.
What exactly is wrong with your existing outdrive Wayne?
