Re: Centre Of Gravity
it is a coach's job to explain concepts in terms that make sense to his students. Or ask your coach to demonstrate what he is talking about.
Not clear if you are discussing skiing on two or one ski.
This could mean a number of things:
? A comfortable, natural stance. Feet about shoulder width apart, knees slightly bent, arms straight and shoulders back.
? While your arms are obviously attached to your shoulders, it helps me to think of the line being pulled from closer to my "center of mass" which is my navel. (keeping hands lower helps bring the handle lower and thus pulling from your core)
? If slalom skiing and loading the line aggressively, leaning away from the boat, the same body position of knees soft. arms straight, hips up toward the handle and shoulders back will help move the handle (and the pull) closer to your center of mass.
You're stronger that way. more stable. using legs more than the just your back.
