I've only used kitty hair once that I can remember and that was as a filler / build up between layers of woven mat. From what I have been able to read, its primary use is as a filler, NOT for structural strength over a large area.
Here is why I ask, my car is still in the shop (week 6) and when I spoke to the guys in the body shop I was told they repaired the composite hood with kitty hair. To give you an idea, the composite the hood is made of is about 3/16" thick. (give or take, I haven't measured it other than by eyeball.) The deer I hit struck the hood hard enough it was cracked all the way through, cracks visible on the bottom side in a spider web pattern probably about 8" in diameter, about 12" on the top.
The "repair" performed was to sand away the paint and primer, slap kitty hair on it, sand smooth and repaint. My gut feeling is this sort of repair has no real structural strength compared to laying down a woven mat and glassing it. I envision hitting a bad bump when it?s cold (or hot) or someone leans on it, etc. and the filler simply pops out.
Need onions on this repair. Will Kitty hair bond well enough? Is there any structural strength with this sort of fix? At 100+ MPH am I going to watch it crumble before my eyes?
As to why the hood is being repaired instead of replaced, it's no longer available from GM. (Did find one in a warehouse but the guy wanted almost a grand for it and the insurance balked.)
