bob johnson
- Feb 25, 2009
- 4,304
this is the second time i have done a water pump on this motor. the first time everything went well. and I was pumping at least 10 psi at idle and up past 25 psi at WOT.
lately the waterpump has been fluctuating...and never went past 15 at 3500 rpm...
so i had an extra lower unti i rebuilt sitting by and i installed that...I had put a brand new water pyump kit in it..well after installing it will only give me 5 psi at idle and maybe 7 at 2000 rpm....
what could i have likely messed up???
I am using rabbit ears to run the motor in the yard....does it not have a prime? the tell tale is OK...not strong like I like.....when running good the tell tale is a STRAIGHT line of water...now it archs down when in use at idle.
or did i justnot seal something???
is it possible i have ruined the impeller ...is there something i could reset if i took this unit off and removed the kit and re-install??
seemed so simple....and worked the first time .
bob
bob
