Re: 1991 evinrude 25 hp troubles
Welcome to the forum.
We're probably going to get to the point where someone will ask for model number. This will help a lot when it comes to parts like the carburetor.
Until then, let's hear more of how it runs.
Will it throttle up in the barrel or with muffs?
When you try to throttle up on the water, does the engine rev up or die out?
If the engine dies out, it is probably starving for fuel.
If it revs up and goes nowhere, you have probably spun the prop on the hub.
What did the carb cleaning consist of?
J
